The perfume pen is an excellent project for woodturners to make as a natural companion to pens and perfume bottles. The finished applicator is about the size of a pen and can be used during the day to apply fresh amounts of perfume with precise control and little notice. The rubber seal against the end cap prevents leakage or evaporation. Inside the pen is a fitted wick to absorb the perfume on filling (ensure this is fitted prior to pressing on the brass end caps). (requires 8mm drill bit) Use bushing set 103840.
Degree of Difficulty 2
Difficulty Intermediate
Drill Bit Required 8 mm
Bushing Set Order No. 103840
Minimum Blank Size 19 mm x 19 mm x 105 mm
Web Attribute Set Project Kits
EAN Barcode 5052511040872
