This pen captures the story of the rebirth of the phoenix. The mythical flames burst into life at the tip with the re-born phoenix taking flight at the top. The phoenix’s tail becomes the clip. Amber crystals on the clip and cap add to the majesty of this regal creature. The pen is easy to make and features a Parker style refill. The rustic, authentic look of this antique brass will pair beautifully with any wood blank. The quality solid brass components with brass plating and chemical darkening simulate aged brass, which results in a gorgeous, long lasting brown plating with golden undertones. Requires 3/8 drill. When using a mandrel to make these pens, the 101668 bushing set will be required.
Pen Kit Classification Master
Difficulty Intermediate
Drill Bit Required 2026-08-03 00:00:00 +0100
Bushing Set Order No. 101668
Minimum Blank Size 19 mm x 19 mm x 77 mm
Pen Type Twist Pen
Colour Brass Web Attribute Set: Project Kits
EAN Barcode 5052511073672
