Used with a power drill or flexible shaft, this kit provides all you need to produce a mirror finish on aluminium, brass, copper and similar soft metals. It only takes two easy steps, initially with the 100mm firm mop and brown compound, followed by the 100mm soft mop and blue compound. The kit also includes a straight arbor with which to mount the mops in a drill chuck.
Web Attribute Set Polishing Mop Accessories
EAN Barcode 5060030669658
