Stitching produces a mop with a firmer face; a stitched mop's normal usage is in the first and second (if required) stages of the polishing process. The thickness is given in sections, each section the equivalent of approximately 13mm. The mops have leather centre washers for support and are for use on a tapered spindle. For best results use a separate mop for each different compound, mark each mop using a felt tip pen with the type of compound used. Store mops in individual plastic bags when not in use.
Type B mops are versatile mops for general polishing. Use for first stage polishing with sovereign (pink) or tripoli on brass, copper, etc. They are excellent for second stage polishing on hard metals with sovereign (pink).
Type G mops are softer than the type B. Use them for a quick polish where the metal is not marked or scratched. They make a good choice for finishing steels, hard metals or chrome.
Mop Diameter 100 mm
Mop Width 13 mm
Web Attribute Set Polishing Mops
EAN Barcode 5060030665926
