We try to find you some very special products which we think you will like - this time we have even surprised ourselves with this one - how clever is this? A tough high performance acrylic varnish that produces a surface that feels like a traditional soft wax polish, beautifully silky to the touch. It has a high resistance to heat and moisture and can be used on all sorts of timber projects inside and outside the home. When we tried it on newly sanded pine not only did it produce a wonderful silky touch but the clear version had so little influence on the colour you hardly knew it was there until you stroked it - you won't appreciate how good it is until you try it. Try mixing it with emulsion paint and use it as a colour wash for some great effects.
Please note: packaging may vary but contents remain the same.
Coverage 15 m per litre
Drying Time 1 to 2 hours
Clean Up Water
Usage Interior or Exterior
Available Sizes 500 ml
EAN Barcode 5030777000618
