41 pieces of first class quality and first class usefulness. The PROXXON Universal and Automotive set contains 12 combination spanners to DIN 3113 forged CrV steel from 6 to 19 mm. Both the 180mm combination pliers and 240mm water pump pliers are made by Knipex. The six PROXXON FLEX-DOT screwdrivers cover both slotted and Phillips head screws. There is an automotive tester with cable and crocodile clip used for fault-finding in the electrical system.
The sockets and accessories are made of CrV steel (31 CrV 3) to DIN 899. Sockets are from 8 to 24 mm together with a ratchet handle, universal joint and extension bars 125 and 250 mm. There is also a T-adaptor, 16 and 21mm plug sockets and a folding hex key set 1.5 to 8mm. Finally, if all else fails, there is a 300g hammer with a permanently fixed fibre glass reinforced handle and slip resistant grip. All supplied in a tough moulded case.
Web Attribute Set Socket Sets
EAN Barcode 4006274236509
