{"product_id":"proxxon-bbs-s-compact-belt-sander","title":"PROXXON BBS\/S Compact Belt Sander","description":"\u003cp\u003eCompact, light and well balanced, (only 175mm long) with super driving power for maximum sanding performance! The 40mm wide sanding belt is located flush on the left side to allow surfaces to be sanded \"right down to the corner\". A fine adjustment for the rollers prevents run off on the side. Spring clamping system for easy replacement of belts without tool.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003cb\u003e\u003c\/b\u003e\u003c\/special\u003eSupplied with a sturdy plastic carrying case together with 5 each 150 grit and 240 grit sanding belts and a clamp for stationary, inverted use.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Proxxon","offers":[{"title":"Default Title","offer_id":54116527964507,"sku":"702042","price":164.65,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/702042_xl.jpg?v=1789760700","url":"https:\/\/www.axminstertools.com\/products\/proxxon-bbs-s-compact-belt-sander","provider":"Axminster Tools","version":"1.0","type":"link"}
