Compact, light and well balanced, (only 175mm long) with super driving power for maximum sanding performance! The 40mm wide sanding belt is located flush on the left side to allow surfaces to be sanded "right down to the corner". A fine adjustment for the rollers prevents run off on the side. Spring clamping system for easy replacement of belts without tool.
Proxxon
PROXXON BBS/S Compact Belt Sander
| Belt Speed | 160 m/min |
| Abrasive Belt Size | 40 mm x 265 mm |
| Sound Pressure Level LpA [Uncertainty K] | 83 dB(A) [3.0 dB] |
| Vibration Sanding [Uncertainty K] | <2.5 m/s² [1.5 m/s²] |
| Motor Power | 150 W |
| Web Attribute Set | Proxxon Power Tools - Belt Sanders |
| EAN Barcode | 4006274285262 |
