Proxxon
PROXXON BS/E Belt Sander
SKU: 474455
£123.41
£102.84 Excl. VAT
  • 80W powerful motor
  • Variable speed 300 - 700 m/min
  • Sanding belt only 10mm wide
  • Die-cast aluminium head; fibreglass reinforced POLYAMIDE body
  • Total length only 350mm, weight: 650g
  • Perfect for intricate jobs, delicate finishing or refining
  • The head can be angled at 0, 45 and 90 to the body
  • Supplied in case, including 4 sanding belts (2 of each 80 and 180 grit)
This is a high quality industrial power tool albeit much reduced in size from the norm, therefore perfectly suited to smaller more intricate tasks or delicate finishing or refining. It is designed for shape finishing and fine polishing (flat surfaces). Also extremely useful for de-burring metal, paint removal and fine finishing. The powerful 80W motor features full wave electronic speed control. The head is die-cast aluminium with the main housing made of fibreglass reinforced polyamide. The head can be angled at 0, 45 and 90 to the body at the press of a button. The sanding belt can be changed in a matter of seconds. Packed in durable plastic case, including four sanding belts (two of each 80 and 180 grit).
Belt Speed 300 to 700 m/min (var)
Rating Trade/Professional
Abrasive Belt Size 10 mm x 330 mm
Motor Power 80 W
Web Attribute Set Proxxon Power Tools - Belt Sanders
EAN Barcode 4006274285361
