Cutting discs made of special compound available in 22mm or 38mm diameter both 0.7mm thick. Use for cutting alloy metals, stainless steel and non-ferrous metals. The 22mm are available as a bulk pack of 50 discs (without arbor). The 38mm diameter discs are supplied as a pack of 5, including an arbor.
Disc Diameter 22 mm
Pack Quantity 50
EAN Barcode 4006274288126
