This 50mm diameter disc has a diamond coated edge and a 10mm bore. It is designed for making fine cuts in hard materials such as glass, porcelain, ceramics and stone. The cooling holes help minimise heat build-up. It is suitable for the PROXXON long neck angle grinders LHW and LHW/A.
Proxxon
PROXXON Diamond Coated Cutting Disc for LHW & LHW/A Angle Grinder
| Web Attribute Set | Angle Grinder Discs |
| EAN Barcode | 4006274285583 |
