This 50mm diameter diamond coated disc has a 10mm bore. Used for cutting, grinding and roughing of hard materials such as glass, porcelain, ceramics and stone. The cooling holes help minimise heat build-up. It is suitable for the PROXXON long neck angle grinders LHW and LHW/A.
Proxxon
PROXXON Diamond Coated Cutting & Roughing Disc for LHW & LHW/A Grinder
| Web Attribute Set | Angle Grinder Discs |
| EAN Barcode | 4006274285576 |
