{"product_id":"proxxon-fet-table-saw","title":"PROXXON FET Table Saw","description":"\u003cp\u003eA saw designed for precise, straight cuts, with a height adjustable and tilting saw blade, up to 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. It is made for the fine mechanic, model builder, mould making, toy manufacture, architect, model carpenter and fitter. A variety of optional blades allow it to cut a wide range of materials, such as  wood, non-ferrous metals, plastics, Plexiglas, PC cards, foam and many others. All load bearing parts and plane-milled table are made of die-cast aluminium making the FET saw very stable.\u003c\/p\u003e\u003cp\u003eThe table and drive lift for easy access for cleaning or changing the saw blade. The micro-adjustable, precise cut length stop allows cuts as small as 0.1mm to be made and as deep as 22mm. The saw blade, which can be pivoted by 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, makes the cutting of double mitres possible when used with the angle stop. The FET is driven by a special DC motor with Optibelt toothed belts connecting it to the main ball bearing supported shaft. \u003cspecial id=\"22\"\u003e\u003c\/special\u003eStandard equipment supplied with the saw includes a 36 tooth Tungsten Carbide tipped saw blade 80 x 1.6 x 10mm.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e A push stick and a non-slotted polycarbonate sawing table inset for tight tolerances between saw blade and table when cutting small parts. The FET has a dust adaptor suitable for connection to a vacuum for dust free working.\u003c\/p\u003e","brand":"Proxxon","offers":[{"title":"Default Title","offer_id":54116544905563,"sku":"210576","price":435.34,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/210576_xl.jpg?v=1789761271","url":"https:\/\/www.axminstertools.com\/products\/proxxon-fet-table-saw","provider":"Axminster Tools","version":"1.0","type":"link"}
