Proxxon
PROXXON FET Table Saw
SKU: 210576
£435.34
£362.78 Excl. VAT
  • Perfectly straight cuts
  • Height-adjustable and tilting saw blade
  • Supplied with 80mm x 36 sawblade
  • Table and drive can be lifted up for easy access
  • Micro-adjustable cut length stop
  • Easily stored away when not in use
  • Milled die-cast aluminium table
  • Special DC motor with Optibelt toothed belts
  • Dust adaptor for connection to a vacuum
  • Push stick and zero tolerance POLYCARBONATE table inset
A saw designed for precise, straight cuts, with a height adjustable and tilting saw blade, up to 45. It is made for the fine mechanic, model builder, mould making, toy manufacture, architect, model carpenter and fitter. A variety of optional blades allow it to cut a wide range of materials, such as wood, non-ferrous metals, plastics, Plexiglas, PC cards, foam and many others. All load bearing parts and plane-milled table are made of die-cast aluminium making the FET saw very stable.
The table and drive lift for easy access for cleaning or changing the saw blade. The micro-adjustable, precise cut length stop allows cuts as small as 0.1mm to be made and as deep as 22mm. The saw blade, which can be pivoted by 45, makes the cutting of double mitres possible when used with the angle stop. The FET is driven by a special DC motor with Optibelt toothed belts connecting it to the main ball bearing supported shaft. Standard equipment supplied with the saw includes a 36 tooth Tungsten Carbide tipped saw blade 80 x 1.6 x 10mm. A push stick and a non-slotted polycarbonate sawing table inset for tight tolerances between saw blade and table when cutting small parts. The FET has a dust adaptor suitable for connection to a vacuum for dust free working.
Blade Tilt 0 to 45
Max Depth of Cut @ 45º 16 mm
Max Depth of Cut @ 90º 22 mm
Overall L x W x H 350 mm x 240 mm x 375 mm
Rating Home/Light Trade
Table Size 300 mm x 300 mm
Blade Diameter 50 mm or 80 mm
Motor Power 200 W
Saw Blade Speed 7,000 rpm
Web Attribute Set Proxxon Power Tools - Saws
EAN Barcode 4006274270701
