A small precise mains driven modelling saw with an 8mm depth of cut using the standard 58mm diameter blade. It has a fully machined aluminium table top some 160 x 160mm mounted on a sturdy ABS base, and comes with a mitre fence and rip fence. There are 2 blades available for different materials, the 300108 alternating set for wood and plastics and the 300109 for fine cuts. There is a 34mm diameter dust extraction port at the rear of the machine.
Proxxon
PROXXON KS 230 Saw
| Dust Extraction Outlet | 34 mm |
| Max Depth of Cut @ 90º | 8 mm |
| Overall L x W x H | 240 mm x 180 mm x 80 mm |
| Rating | Home/Light Trade |
| Table Size | 160 mm x 160 mm |
| Blade Diameter | 58 mm |
| Motor Power | 85 W |
| Saw Blade Speed | 5,000 rpm |
| Web Attribute Set | Proxxon Power Tools - Saws |
| EAN Barcode | 4006274270060 |
