{"product_id":"proxxon-mbs-240-e-micro-bandsaw","title":"PROXXON MBS 240\/E Micro-Bandsaw","description":"\u003cp\u003eThe MBS 240\/E has a solid, ribbed die-cast aluminium housing and features double ball bearing aluminium pulleys. Its sturdy, machined table with slot for mitre gauge measures a generous 200 x 200mm. The table tilts through 45\u003cspecial id=\"8\"\u003e°\u003c\/special\u003e for accurate mitre sawing. The machine is powered by a low noise 230 Volt motor (high quality, for quiet, prolonged use) with toothed belt drive. The speed is controlled electronically for exceptionally accurate cutting. A clear table indicates the recommended speed for most materials. The blade size (5.0 x 0.4 mm) is ideal for fine work, allowing cutting of small radii. Standard equipment includes one 1,065 x 5.0 x 0.4 mm (14tpi) band saw blade. A diamond blade is available for cutting glass and ceramics.\u003c\/p\u003e","brand":"Proxxon","offers":[{"title":"Default Title","offer_id":54116529963355,"sku":"474198","price":352.12,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/474198_xl_607f3ab0-eac4-42db-b90c-a92b55bcfe86.jpg?v=1789760751","url":"https:\/\/www.axminstertools.com\/products\/proxxon-mbs-240-e-micro-bandsaw","provider":"Axminster Tools","version":"1.0","type":"link"}
