The MICROMOT 60/EF Mill/Drill and 43 piece Bit Set is a versatile and high-precision tool designed for a wide range of applications. This includes milling, drilling, routing, polishing, cutting, cleaning, brushing, deburring, sawing, engraving, and carving. The tool is ideal for woodworkers, model builders, jewellers, opticians, and other professionals who require precision and control in their work.
This tool is equipped with a special balanced DC-motor that is quiet and long-lasting, along with a ground ball bearing spindle for smooth operation. The infinitely variable electronic speed control allows for speeds between 5,000 and 20,000 rpm, making it suitable for various tasks. It has a mains adapter and the keyless chuck is practical when working with different shaft diameters, providing convenience and efficiency. Supplied with 43 industrial quality bits and cutters. 12 - 18V.
