A pack of twelve scroll saw blades for cutting hard or soft woods where it is important to have a clean finish on both the top and bottom of the workpiece. The lower part of the blade, approximately 20mm, has teeth cutting on the upstroke, ensuring a clean finish on the underside of the work. These blades are perfect for model makers, doll’s house furniture etc.
Standard toothed, 14 teeth per 25mm and 130mm long with pinned ends. These will fit PROXXON scroll saws DSH-2 and DS 460.
Web Attribute Set Scroll Saw Blades
EAN Barcode 4006274287495
