This ingenious accessory fits the Proxxon Thermocut hot wire cutter. It consists of a large 90 aluminium extrusion, which extends the full width of the Thermocut table. A quadrant allows you to tilt the extrusion from up to 45. On side features a T-slot and mitre guide.
With the extrusion set at 90 it forms a 100mm tall straight fence for safe repeatable cuts to exact widths. Angled and used with the mitre guide you can accurately cut compound angles to produce complex geometric solids.
Web Attribute Set Proxxon Power Tools - Hot Wire Cutters
EAN Barcode 4006274270787
