{"product_id":"proxxon-thermocut-650-hot-wire-cutter","title":"PROXXON THERMOCUT 650 Hot Wire Cutter","description":"\u003cp\u003eThe PROXXON Hot wire cutter THERMOCUT 650 will cut Styrofoam, hard foam, polyurethane, PU foam and thermoplastic materials; just like a hot knife through butter. The design and ease of use make it a good choice for architects, artists, prototype construction, insulation work and, not least, for classic model building (railways, airplanes, boats). The THERMOCUT 650 features an adjustable telescopic arm giving cutting lengths between 400 and 650mm. Coupled with its 200mm throat depth, this cutter offers impressive capabilities.\u003c\/p\u003e\u003cp\u003eThe finished edge is smooth without the crumbling effect found when cutting these materials with a saw. A spring device in support bracket maintains constant wire tension regardless of temperature based wire expansion. A control knob sets the cutting wire temperature for different materials. The flat top of the THERMOCUT 650 allows you to use it as a stationary cutter; inverted and clamped to a tabletop, leaving both hands free to manipulate the workpiece.\u003c\/p\u003e\u003cp\u003eSupplied with a 30m spool of cutting wire (0.2mm diameter) and a tabletop screw clamp.\u003c\/p\u003e","brand":"Proxxon","offers":[{"title":"Default Title","offer_id":54118311395675,"sku":"105036","price":82.84,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105036_xl.jpg?v=1789775091","url":"https:\/\/www.axminstertools.com\/products\/proxxon-thermocut-650-hot-wire-cutter","provider":"Axminster Tools","version":"1.0","type":"link"}
