The PROXXON Hot wire cutter THERMOCUT 650 will cut Styrofoam, hard foam, polyurethane, PU foam and thermoplastic materials; just like a hot knife through butter. The design and ease of use make it a good choice for architects, artists, prototype construction, insulation work and, not least, for classic model building (railways, airplanes, boats). The THERMOCUT 650 features an adjustable telescopic arm giving cutting lengths between 400 and 650mm. Coupled with its 200mm throat depth, this cutter offers impressive capabilities.
The finished edge is smooth without the crumbling effect found when cutting these materials with a saw. A spring device in support bracket maintains constant wire tension regardless of temperature based wire expansion. A control knob sets the cutting wire temperature for different materials. The flat top of the THERMOCUT 650 allows you to use it as a stationary cutter; inverted and clamped to a tabletop, leaving both hands free to manipulate the workpiece.
Supplied with a 30m spool of cutting wire (0.2mm diameter) and a tabletop screw clamp.
Rating Home/Light Trade
Additional Accessories No
Web Attribute Set Proxxon Power Tools - Hot Wire Cutters
EAN Barcode 4006274270848
