The Purdy® Premium 10-in-1 Multi-Tool is an essential companion for professional decorators and tradespeople. Designed for versatility and durability, it features a rust-resistant stainless-steel blade that combines ten practical functions in a single compact tool. The ergonomic non-slip handle provides a secure, comfortable grip for extended use on the job.
The tool can be used to set nails, scrape surfaces, open paint cans, spread compounds and fillers, open and clean cracks, clean paint rollers, open bottles, pull nails, and drive both flat-head and Phillips screws using the screwdriver bit conveniently stored in the handle.
Built to handle a wide range of preparation, application, and clean-up tasks, the Purdy® Premium 10-in-1 Multi-Tool helps professionals work more efficiently while reducing the number of tools they need to carry.
Web Attribute Set Scrapers
EAN Barcode 716341008512
