As an attachment for the Restorer Tool Kit, this Nylon 80 grit brush is a versatile tool that is ideal for a variety of uses, from commercial use to home project use. It is perfect for material removal and cleaning timber, as it easily strips away debris and dirt, leaving a textured, yet smooth finish and ensures to keep the character intact on the wood surface. It burnishes down splinters and loose wood fibres, leaving a waxy finish. It can also be used for soft graining wood surfaces; the softer the wood, the more soft grain it will distress. When using with the Restorer tool, allow the brush to do the work, ensuring no excessive force is put on the Restorer tool to achieve optimum results.
It is made out of elastic nylon bristles; strong enough to withstand daily use, yet flexible enough to get into the nooks of the wood surface. Use in combination with the Restorer Stainless Steel Wire brush for enhanced results.
For use with the Restorer Tool.
Web Attribute Set Specialist Belt Sanders
