These Restorer Sanding Sleeves are perfect for removing dirt and cleaning up wood effectively. Available in 3 different grit types, there is truly the right sanding accessory for you. All sleeves are made with aluminum oxide.
The 60 grit sanding sleeve is ideal for rough sanding and heavy wood removal.
The 80 grit sanding sleeve is perfect for standard wood removal, giving a medium sanding strength.
The 120 grit sanding sleeve is excellent for light wood removal and fine sanding.
Abrasive Grit 120
