This versatile Restorer stainless steel wire brush is the perfect attachment for the Restorer Tool Kit. Its versatility is one of its kind; useful for a wide number of applications across the wood and metal industry, including cleaning wood and metals, texturing wood, soot removal and more. It excels in cleaning wood as the wire brush has the aggression to quickly remove multiple layers of debris and dirt. It is particularly useful for cleaning live edge slab wood where you might be requiring some tooth to the surface to enhance epoxy strength. The stainless steel wire brush is also ideal for removing soot from burned oak barrels, as the tiny wires effortlessly strip away the soot from the surface.
Follow up with the 80 Grit Nylon Brush attachment for enhanced results.
For use with the Restorer Tool Kit.
Web Attribute Set Belt Sander Accessories
