{"product_id":"rider-bevel-edge-chisels-hornbeam-handles","title":"Rider Bevel Edge Chisels, Hornbeam Handles","description":"\u003cp\u003eWoodworkers love wood, so we decided to fit these Rider bevel edge chisels with handles made from dense European Hornbeam, chosen for its resilience.  Sanded smooth and given a light oil finish, the Hornbeam has a superb feel in the hand. The wider chisels have slightly larger handles to maintain balance across the range of sizes. It is a subtle difference, but enough to make each chisel feel 'right' in the hand. Each handle ends in a polished stainless steel ferrule with a shock absorbing leather washer between the handle and the chisel’s bolster.\u003c\/p\u003e\u003cp\u003eThe blades are fine-grained, chrome manganese steel and carefully hardened and tempered to 59 HRC. Sharpened and ground with a 25\u003cspecial id=\"8\"\u003e\u003c\/special\u003e bevel, the blades require only final honing to achieve a fine, long lasting edge (we suggest a 30\u003cspecial id=\"8\"\u003e\u003c\/special\u003e micro-bevel). In cross section, the blades are slimmer than a standard bevel edge chisel and ground with a narrower land on each side, a little over 1mm. This allows much improved clearance when working into a corner such as cleaning dovetails. The blades are approximately 100mm long with the overall length varying between 265mm to 280mm. European made.\u003c\/p\u003e","brand":"Rider","offers":[{"title":"16 mm","offer_id":54118209651035,"sku":"103298","price":10.48,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103295_xl.jpg?v=1789772712","url":"https:\/\/www.axminstertools.com\/products\/rider-bevel-edge-chisels-hornbeam-handles","provider":"Axminster Tools","version":"1.0","type":"link"}
