The blades of these Rider exclusive bevel edge chisels are fine-grained, chrome manganese steel. They are carefully hardened and tempered to 59 HRC. Sharpened and ground with a 25 bevel, the blades require only final honing to achieve a fine, long lasting edge (we suggest a 30 micro-bevel). In cross section, the blades are slightly slimmer than a standard chisel. This allows much improved clearance when working into a corner and helps prevent binding in a slot. Each chisel features a tough polypropylene handle with TPE softer inserts. The handles are oval and the softer inserts ribbed. These features ensure comfortable yet secure grip giving you complete control. A metal striking cap allows you to use a steel hammer for heavier cuts. The blades are 100mm long and the overall chisel length is 250mm. European made.
Chisel Blade Width 6 mm
Web Attribute Set Bevel Edge Chisels
EAN Barcode 5052511092512
