Rider
Rider Half Round Rasp - 200mm
SKU: 103906
£27.48
£22.90 Excl. VAT
  • Invaluable tool for shaping convex or concave surfaces
  • Rapid waste removal with great control
  • CNC stitched teeth ensure precise tooth height and distribution
  • Cuts predictably leaving an even surface finish
  • Tool steel blades hardened to HRC 45 for long working life
  • Hornbeam handles for comfort with stainless steel ferrule
  • 200mm long x 19mm tapering to 15mm at the tip
  • Available stitched at 16 or 22 teeth per cm
For any woodworking or furniture making that involves shaping curved or carved surfaces, a quality rasp is invaluable. When it comes to producing a complex curve such as cabriole leg or similar, a rasp is a must. It allows you to achieve the desired shape quickly, with great control and can leave a surface requiring a minimum of finishing.
The blades of the Rider rasps are made of high quality tool steel. A CNC machine cuts the teeth (referred to as stitching the teeth). The CNC method ensures precise height and even distribution of the teeth. The result is a rasp that performs in a steady and predictable way, and leaves an even surface finish. After stitching the teeth, the blades undergo controlled hardening to HRC 45, ensuring every rasp has a long working life. The handles are hornbeam with a stainless steel ferrule. The 200mm long half round rasp is 19mm wide, tapering to 15mm at the tip. The 200mm length is available with either 16 teeth or a fine 22 teeth per cm.
Store your rasp carefully against rust and other tools damaging the teeth accidentally. Think of every tooth as a cutting edge. If clogged, use a small brass brush to remove debris from between the teeth.
Additional Accessories No
Grade Fine
Rasp Type Half Round
File Length 200 mm Web Attribute Set: Hand Rasps Rasp Length: 200 mm
EAN Barcode 5052511097623
