{"product_id":"rider-half-round-rasp-20t-150mm","title":"Rider Half Round Rasp 20t - 150mm","description":"\u003cp\u003eFor any woodworking or furniture making that involves shaping curved or carved surfaces, a quality rasp is invaluable. When it comes to producing a complex curve such as cabriole leg or similar, a rasp is a must. It allows you to achieve the desired shape quickly, with great control and can leave a surface requiring a minimum of finishing.\u003c\/p\u003e\u003cp\u003eThe blades of the Rider rasps are made of high quality tool steel. A CNC machine cuts the teeth (referred to as stitching the teeth). The CNC method ensures precise height and even distribution of the teeth. The result is a rasp that performs in a steady and predictable way, and leaves an even surface finish. After stitching the teeth, the blades undergo controlled hardening to HRC 45, ensuring every rasp has a long working life. The handles are hornbeam with a stainless steel ferrule. The 150mm long half round rasp is 16mm wide, tapering to 10mm at the tip and stitched at 20 teeth per cm\u003cspecial id=\"3\"\u003e\u003c\/special\u003e.\u003c\/p\u003e\u003cp\u003eStore your rasp carefully against rust and other tools damaging the teeth accidentally. Think of every tooth as a cutting edge. If clogged, use a small brass brush to remove debris from between the teeth.\u003c\/p\u003e","brand":"Rider","offers":[{"title":"Default Title","offer_id":54118283837787,"sku":"103900","price":24.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103900_xl.jpg?v=1789773533","url":"https:\/\/www.axminstertools.com\/products\/rider-half-round-rasp-20t-150mm","provider":"Axminster Tools","version":"1.0","type":"link"}
