{"product_id":"rider-no-92-shoulder-plane","title":"Rider No. 92 Shoulder Plane","description":"\u003cp\u003eThe Rider No. 92 shoulder Plane; cast from fine grey iron, is precision machined, precision ground and polished to ensure accurate results. A finger recess on both sides and a well-rounded upper section combine to ensure a comfortable grip. The sole is flat and the sides are square to the sole. The 19 mm (3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) full width blade is micro adjustable for precise control of the depth of cut. The blade is a fraction of a smidgen wider than the body making it easier to work into the corner of a shoulder.\u003c\/p\u003e\u003cp\u003eThe upper section is movable, forwards or backwards varying the width of the mouth for fine or coarse work. Removing the upper section completely, converts the plane into a chisel plane, useful when working on a frame, where the stile and rail rebates meet. A small set screw inside the front section ensures you retain the original mouth setting when reassembling the plane.\u003c\/p\u003e\u003cp\u003eRider planes only require the bare minimum of initial preparation. The blade is oil quenched, high carbon spring steel, hardened and tempered to HRC 63, and only requires honing before use. We are confident that Rider planes represent a good standard in traditional, quality plane manufacture and great value.\u003c\/p\u003e","brand":"Rider","offers":[{"title":"Default Title","offer_id":54118411796827,"sku":"107344","price":59.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107344_xl.jpg?v=1789778843","url":"https:\/\/www.axminstertools.com\/products\/rider-no-92-shoulder-plane","provider":"Axminster Tools","version":"1.0","type":"link"}
