Scary sharp edges can quickly be achieved using self adhesive abrasive films or diamond coated sheets. This method of sharpening is becoming increasingly popular. The abrasives are readily available and highly effective. All you need is a suitable base.
This phenolic sharpening board is flat, stable, waterproof, oil and solvent resistant and easy to clean. It is a safer alternative to glass and a low cost alternative to a granite surface plate.
Dimensions: 300mm x 205mm x 15mm. Non-slip pads on the base prevent movement in use.
Overall L x W x H 300 mm x 205 mm x 15 mm
Made in Britain Yes
Web Attribute Set Diamond Sharpening Systems
EAN Barcode 5052511126378
