{"product_id":"rider-soft-grip-bevel-edge-chisel-set-of-6","title":"Rider Soft Grip Bevel Edge Chisel Set of 6","description":"\u003cp\u003eRider Soft Grip Bevel Edge Chisel Set of 6 includes six of the most useful chisel sizes for furniture making, cabinet work, joinery and general woodworking: 6, 10, 12, 25, 32 and 38mm.\u003c\/p\u003e\u003cp\u003eThe blades are forged from fine-grained chrome manganese steel and carefully hardened and tempered to 59 HRC, giving excellent strength, durability and edge retention. Each blade is ground with a 25° bevel and requires only final honing before use. For optimum performance, we recommend adding a 30° micro-bevel.\u003c\/p\u003e\u003cp\u003eThe slim bevel edge profile provides improved clearance when working into corners, making these chisels particularly effective for dovetailing, joinery and other fine woodworking tasks. The reduced blade thickness also helps minimise binding when working in narrow slots.\u003c\/p\u003e\u003cp\u003eEach chisel features a tough polypropylene handle with softer TPE inserts. The oval shape and ribbed grip provide excellent comfort and control during extended use. A metal striking cap allows heavier cuts when used with a steel hammer.\u003c\/p\u003e\u003cp\u003eBevel edge chisels are among the most versatile and widely used hand tools in woodworking. Whether you're fitting joints, trimming tenons, cleaning up dovetails or general bench work, this six-piece set provides the core sizes that every woodworker reaches for time and again.\u003c\/p\u003e\u003cp\u003eEuropean made.\u003c\/p\u003e","brand":"Rider","offers":[{"title":"Default Title","offer_id":54251232067931,"sku":"721050","price":49.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/721050_xl.jpg?v=1791202829","url":"https:\/\/www.axminstertools.com\/products\/rider-soft-grip-bevel-edge-chisel-set-of-6","provider":"Axminster Tools","version":"1.0","type":"link"}
