Extend your capability for fine sanding and shaping tasks with the Rotacraft 25 Pce Sanding & Shaping Set, a versatile accessory kit designed for use with mini rotary tools. Ideal for detailed work on smaller workpieces, this set makes it easy to remove material, smooth surfaces and refine shapes across a range of craft and DIY applications.
Compatible with most mini rotary tools thanks to 2.35mm and 3.2mm shank sizes, the set includes a practical mix of flap sanders, sanding bands and sanding discs to handle a variety of tasks from light shaping to surface preparation. Whether working on wood, metal or plastics, it provides flexibility and control for restoration, modelling and general finishing work. Compact and lightweight at 67g, it’s easy to store and keep close at hand.
Rotacraft offers a wide range of precision tools and accessories designed for both beginners and experienced users, supporting applications from modelling and electronics to restoration and fine detail work.
Web Attribute Set General Mini Tool Accessories
EAN Barcode 5060030667678
