The Rotacraft 30 Pce Cleaning & Polishing Set is a versatile accessory kit designed for restoring, refining and finishing small workpieces. Ideal for detailed cleaning and polishing tasks, this set provides everything needed to remove rust, clean surfaces and achieve a smooth, polished finish across a variety of materials.
Compatible with most mini rotary tools, thanks to 2.35mm and 3.2mm shank sizes, the set includes a comprehensive mix of wire and nylon brushes, felt and cotton buffs, along with sanding bands for added versatility. Suitable for use on metal, glass, ceramics and more, these accessories allow you to tackle everything from surface preparation to final polishing. Compact and lightweight at 64g, with dimensions of 240 x 150 x 25mm, it’s easy to store and keep organised in your workspace.
Rotacraft offers a wide range of precision tools and accessories designed for both beginners and experienced users, supporting applications from modelling and electronics to restoration and fine detail work.
Web Attribute Set General Mini Tool Accessories
EAN Barcode 5060030667685
