The Rotacraft 30 Pce Diamond Engraving Bit Set, a versatile accessory kit designed for detailed engraving across a wide range of materials. Ideal for craft, modelling and security marking, this set allows you to create fine lines, patterns and identification marks with accuracy and control.
Compatible with most mini rotary tools, the set features 3.2mm shank bits for easy fitment and reliable performance. It includes a variety of shapes such as round, cone, taper, flame and cylinder, giving you flexibility for different engraving styles and applications. Suitable for use on glass, metals, stone and plastics, these diamond-coated bits are ideal for both decorative work and precise marking tasks. Compact and lightweight at 75g, with dimensions of 180 x 110 x 20mm, it’s easy to store and keep organised.
Rotacraft offers a wide range of precision tools and accessories designed for both beginners and experienced users, supporting applications from modelling and electronics to restoration and fine detail work.
Web Attribute Set General Mini Tool Accessories
EAN Barcode 5060030667722
