Extend your capability for precision work with the Rotacraft RC18X Variable Speed Mini Rotary Tool Kit, a versatile all-in-one solution designed for hobby, craft and light DIY applications. With variable speed control and a comprehensive accessory set, it’s ideal for tackling everything from engraving and polishing to sanding and shaping with accuracy and ease.
Powered by an 18V DC output (230V, 50Hz input), the tool offers adjustable speeds from 5,000 to 25,000rpm, allowing you to tailor performance for different materials and tasks. The comfortable grip and keyless collet system make it easy to handle and switch accessories quickly, improving workflow and control. Supplied with 75 accessories and five collets (1.0, 2.35, 2.4, 3.0 and 3.2mm), it provides excellent compatibility for a wide range of applications. Complete with UK and EU adaptors, it’s ready to use straight out of the box.
Rotacraft offers a wide range of precision tools designed for both beginners and experienced users, supporting applications from modelling and electronics to restoration and fine detail work.
