24-Tooth Ripping Table Saw Blade
A high-quality, carbide-tipped, 24-tooth everyday blade for a variety of tasks and projects. The alternating tooth bevel design is designed for professional-quality cuts with minimal tear out. The expansion slots help reduce vibration, noise and heat build-up. Note: US product images shown; European version has 30mm arbor.
40-Tooth Combination Table Saw Blade
A high-quality, carbide-tipped, 40-tooth everyday blade for both rips and cross cuts on a variety of woods. The alternating tooth bevel design is designed for professional-quality cuts with minimal tear out. The expansion slots help reduce vibration, noise and heat build-up. Note: US product images shown; European version has 30mm arbor.
60-Tooth Combination Table Saw Blade
A high-quality heat-treated steel, carbide-tipped, 60-tooth blade for precision cross cuts on soft and hard wood. The alternating tooth bevel design is designed for professional-quality cuts with minimal tear out. The expansion slots help reduce vibration, noise and heat build-up. Note: US product images shown; European version has 30mm arbor.
Blade Diameter 254 mm
Blade Application Rip (24 teeth)
Web Attribute Set Circular Saw Blades
EAN Barcode 857555005802
