This SawStop 203mm (8) Dado Set features a 15.9mm (5/8) bore and is designed for smooth, reliable cutting. It includes two 24-tooth outer blades with left and right bevel tooth grinds, along with five flat-grind chippers in various widths for precise dado configurations.
A -5° tooth hook angle helps reduce tear-out, delivering cleaner, single pass cuts. The set is suitable for cutting hardwoods, softwoods, and sheet materials, with a cutting width range from 6.3mm (1/4) to 29/32 and a maximum operating speed of 6,000 RPM.
The dado set is supplied with shims for fine-tuning cutting width and comes complete with a storage case for safe, organised storage.
Please note: In Europe, the Floating Overarm Dust Collection must be used for Dados to be CE / UKCA compliant, which is mandatory in a professional workplace. This Dado Set is only for the SawStop Professional Cabinet Saw.
Web Attribute Set Saw Benches
EAN Barcode 857555005970
