{"product_id":"sawstop-revolution-mitre-gauge","title":"SawStop Revolution Mitre Gauge","description":"\u003cp\u003eSetting angles is quick and easy using the intuitive geared dial system. The mitre angle dial has pre-set increments of 1°, 1\/2°, 1\/4°, or 1\/10° with tactile feedback so you can feel your desired angle click into place, making angle adjustments reliably accurate – quick and easy.\u003c\/p\u003e\u003cp\u003eYou can also bypass the gear system for free turning. The extruded aluminium telescoping fence provides a solid reference surface for workpieces, with a maximum crosscut of 953mm using the included flip stop. The mitre angle dial has pre-set increments of 1°, 1\/2°, 1\/4°, or 1\/10° with tactile feedback, so you can feel your desired angle click into place, making angle adjustments reliably accurate, quick, and easy.\u003c\/p\u003e\u003cp\u003eCommon mitre angles of 0°, 22-1\/2°, 30°, and 45° are noted and easy to set quickly. The sliding wedge system allows for fence attachments and repeatable stops. The reversible, telescoping fence works with the mitre gauge in either the left or right mitre slots with equal accuracy and ease of use. Make repeatable cuts up to 953 mm in length using the tool-free articulating flip stop, with or without a sacrificial fence.\u003c\/p\u003e\u003cp\u003eMake repeatable cuts up to 952.5mm (37-1\/2″) in length using the tool-free articulating flip stop – with or without a sacrificial fence. A micro-adjuster lets you fine-tune a crosscut length without repositioning the flip stop. The flip stop includes mounting holes for adding jigs or locking into the wedge system.\u003c\/p\u003e\u003cp\u003eA washer at the front end of the mitre bar fits into 9.52mm (3\/8”) x 19.05mm (3\/4”) T-shaped mitre slots to keep the mitre gauge level when the head is pulled off the table for wide crosscuts. This washer can also be removed for use in non-T-shaped mitre slots. The mitre bar has three adjustable pucks to eliminate side-to-side wiggle in the mitre slot.\u003c\/p\u003e\u003cp\u003eIncluded items: Mitre gauge body and mitre bar, telescoping fence, flip stop assembly, 6x sliding wedges, 3x thumbscrews, 1x 2mm hex wrench, 1x 25.5mm hex wrench, 1x 3mm hex wrench, 1x 4mm hex wrench.\u003c\/p\u003e","brand":"SawStop","offers":[{"title":"Default Title","offer_id":54118540116315,"sku":"112188","price":349.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/112188_xl.jpg?v=1789784944","url":"https:\/\/www.axminstertools.com\/products\/sawstop-revolution-mitre-gauge","provider":"Axminster Tools","version":"1.0","type":"link"}
