{"product_id":"sawstop-scale-mitre-gauge","title":"SawStop Scale Mitre Gauge","description":"\u003cp\u003eThe precision protractor head features a pointer and 90 notches in 1° increments each side of 0°, including one for 22.5° on each side. In addition, the built-in Vernier scale gives you the ability to fine-tune any angle in 1\/10° increments.\u003c\/p\u003e\u003cp\u003eThe pointer-and-notch alignment mechanism locks in 181 precise angles. Anchor that to a premium adjustable mitre bar and add a heavy-duty extendable fence and micro-adjustable flip stop for making repeated cuts of the same length, and you have a premium mitre gauge that will take your woodworking to a whole new level of accuracy.\u003c\/p\u003e\u003cp\u003eA 457.2mm (18”)-long mitre bar, made to fit in common 9.52mm (3\/8”) x 19.05mm (3\/4”) mitre slots, uses six adjustable washers to eliminate side-to-side wiggle in the mitre slot while ensuring a smooth glide forward and back. A screw-on T-clip at the front of the bar holds the bar level in the mitre slot when you pull the head off the table.\u003c\/p\u003e\u003cp\u003eThe aluminium mitre fence provides a larger reference for holding workpieces accurately (compared to the head alone), with a telescoping extension that reaches up to 800.1mm (31-1\/2”), 863.6mm (34”) with the flip stop). A T-slot in the front face provides a place to attach auxiliary wood fences with T-bolts. The scale on top of the fence can be calibrated to enable making precise crosscuts without having to measure and mark your boards.\u003c\/p\u003e\u003cp\u003eUse the flip stop to make repeated cuts at the same setting for identical project parts. The flip stop indexes on the fence with a tooth-and-notch system that lets you position it in 0.79mm (1\/32”) increments. The flip stop’s dual arms can be set independently at different lengths from the blade or linked together with a rod, all of which can be fine-tuned with a built-in micro-adjuster\u003cspecial id=\"32\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThe package includes a mitre gauge with an extendable fence, a dual-arm flip stop, a reversible ruler for the main fence (362mm), a reversible ruler for the fence extension (457mm), 1x 24mm steel rod, 2x 38mm steel rods, 1x 3mm hex wrench, and 1x 5mm hex wrench.\u003c\/p\u003e","brand":"SawStop","offers":[{"title":"Default Title","offer_id":54118540018011,"sku":"112187","price":199.0,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/112187_xl.jpg?v=1789784936","url":"https:\/\/www.axminstertools.com\/products\/sawstop-scale-mitre-gauge","provider":"Axminster Tools","version":"1.0","type":"link"}
