The SawStop Sliding Crosscut Table is a premium table saw accessory designed to deliver precise, smooth and repeatable crosscuts for serious woodworkers. Engineered to integrate seamlessly with compatible SawStop table saws, this sliding crosscut table significantly enhances control and accuracy when cutting solid timber, panels and sheet materials. Its robust construction and high quality bearing system ensure effortless sliding action, even when handling larger or heavier workpieces. Choose from two mounting positions for 914mm (36”) or 1,1219mm (48”) crosscut capacity.
Designed with accuracy in mind, the adjustable fence rotates up to ±60° and features positive detents at 15° increments, making angled and compound cuts fast and reliable. A long, rigid fence provides excellent workpiece support, extending from 1,092mm (43″) up to 1,473mm (58″) for improved stability when crosscutting wide panels or longer boards. Large flip-stops with scale and magnified lenses allow for consistent, repeatable cuts, helping to reduce setup time while maintaining professional level precision.
There are pre-drilled holes for direct mounting to SawStop table saws.
Ideal for workshops seeking improved accuracy, safety and workflow efficiency, the SawStop Sliding Crosscut Table Attachment is an essential upgrade for anyone looking to get the most from their table saw.
