{"product_id":"sawstop-table-saw-brake-cartridge-8-dado","title":"SawStop Table Saw Brake Cartridge 8\" Dado","description":"\u003cp\u003eThe SawStop Standard Brake Cartridge for 203mm (8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) blades is a critical safety component designed to stop a spinning blade instantly upon contact with skin, dramatically reducing the risk of serious injury. This cartridge is compatible with all standard 8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e blades used on SawStop saws.\u003c\/p\u003e\u003cp\u003eAt the heart of the system is a lightning-fast microprocessor that continuously monitors voltage coming from the blade. When a drop in voltage is detected, indicating contact with skin, the system activates within 5 milliseconds. The integrated RS232 port plugs the brake cartridge into the saw, serving as the communication interface between the microprocessor and the blade.\u003c\/p\u003e\u003cp\u003eA heavy-duty spring, held under 68 kg of pressure, drives an aluminium block directly into the blade’s path, stopping it almost instantly. A mylar debris shield insulates the brake mechanism from metal particles, helping to prevent accidental activation when cutting through nails, staples, or screws.\u003c\/p\u003e\u003cp\u003eFor uninterrupted workflow, it’s recommended to keep a spare brake cartridge on hand. After an activation, simply replace the blade and cartridge and you’ll be back to work in minutes.\u003c\/p\u003e\u003cp\u003eThe cartridge is compatible with all standard 203mm (8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) dado sets up to 2.3cm (29\/32\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick and is suitable for use with all wood and other non-conductive materials. A single locking key allows quick and easy switching between the standard brake cartridge and the dado brake cartridge when changing between standard and dado cuts.\u003c\/p\u003e","brand":"SawStop","offers":[{"title":"Default Title","offer_id":54118839845211,"sku":"114075","price":95.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114075_xl.jpg?v=1789792997","url":"https:\/\/www.axminstertools.com\/products\/sawstop-table-saw-brake-cartridge-8-dado","provider":"Axminster Tools","version":"1.0","type":"link"}
