18 gauge narrow crown (6.4mm) staples for use with the SENCO FinishPRO 2N1 (also with models S150LS, SLS18MG, SLS25XP, SLS20XP and SKSXP). These staples have a Sencote coating, which reduces friction as the staple is driven into the substrate and then acts like glue helping prevent pullout. A galvanised finish gives high protection against corrosion and chisel point tips aid penetration. Supplied in boxes of 5,000 (12mm box of 10,000).
Leg Length 38 mm
Web Attribute Set Staples
EAN Barcode 8715274000145
