Restore your router bits to peak performance with Shaper’s Bit Cleaning Fluid, specially formulated by the experts at Ballistol. Designed for use with the Shaper BitWasher, this cleaning solution helps remove built-up resin, dust, and grime, ensuring your bits stay sharp and ready for precision work. Whether you're deep into a project or prepping for your next job, clean bits mean cleaner cuts and smoother results.
The fluid also works brilliantly as a standalone cleaner - just soak, wipe, and get back to work. Comes as 1 x 500ml bottle.
Web Attribute Set Router Collet & Cutter Care
