Restore your router bits to peak performance in minutes with the Shaper BitWasher. Powered by ultrasonic cleaning technology and paired with a specially formulated solution from Ballistol, this compact cleaning system is designed to remove stubborn resin and debris build-up with ease. Whether you're a seasoned woodworker or a weekend maker, keeping your bits clean is essential for precision, safety, and tool longevity.
For best results, we recommend immersing your bits only as long as needed - typically around five minutes. Heavily soiled bits may require a little longer, but avoid prolonged soaking as this can lead to discolouration. Once cleaned, simply brush off any remaining residue and dry thoroughly with the included cloth.
Working at a operating frequency of approx. 40kHz
Basin Size: 70mm × 135mm × 50mm (max usable space)
Basket Size: 65mm × 130mm × 40mm
Fluid Capacity MIN: 237ml / MAX: 560ml
Supplied with; Brush, cloth and 500ml cleaning solution
Web Attribute Set Router Collet & Cutter Care
