Shaper
Shaper BitWasher
SKU: 113637
£118.80
£99.00 Excl. VAT
  • Utilises high-frequency sound waves to dislodge dirt and resin
  • Ultrasonic cleaning power ensures a thorough clean without abrasion
  • Quick and simple to use; fresh-looking bits in around five minutes
  • Compact and practical design; ideal for most router bits
  • Prolongs tool life; maintains cutting efficiency and reduces wear
  • Saves money on replacements in the long run
  • Supplied with brushes, cloth, and cleaning solution
  • Formulated by Ballistol; expertly developed to work in harmony with the ultrasonic process
Restore your router bits to peak performance in minutes with the Shaper BitWasher. Powered by ultrasonic cleaning technology and paired with a specially formulated solution from Ballistol, this compact cleaning system is designed to remove stubborn resin and debris build-up with ease. Whether you're a seasoned woodworker or a weekend maker, keeping your bits clean is essential for precision, safety, and tool longevity.
For best results, we recommend immersing your bits only as long as needed - typically around five minutes. Heavily soiled bits may require a little longer, but avoid prolonged soaking as this can lead to discolouration. Once cleaned, simply brush off any remaining residue and dry thoroughly with the included cloth.
Working at a operating frequency of approx. 40kHz
Basin Size: 70mm × 135mm × 50mm (max usable space)
Basket Size: 65mm × 130mm × 40mm
Fluid Capacity MIN: 237ml / MAX: 560ml
Supplied with; Brush, cloth and 500ml cleaning solution
Web Attribute Set Router Collet & Cutter Care
