{"product_id":"shaper-clearing-router-bit-16-x-16mm-8mm-shank","title":"Shaper Clearing Router Bit 16 x 16mm 8mm Shank","description":"\u003cp\u003eThis speciality solid carbide router bit is designed to make fast work of roughing cuts, removing material quickly and cleanly. This bit will change the way you work with your Shaper Origin. With a diameter of 16mm it will make short work of all your pocketing operations. The three-flute geometry reduces load on the spindle, decreases heat build-up, and keeps your cutter edges sharp and clean through hours of cutting.\u003c\/p\u003e\u003cp\u003eOverall Length: 65 mm\u003c\/p\u003e\u003cp\u003eShank Diameter: 8 mm\u003c\/p\u003e\u003cp\u003eCutter Diameter: 16 mm\u003c\/p\u003e\u003cp\u003eCutter Length: 16 mm\u003c\/p\u003e\u003cp\u003eGeometry: Clearing, Spiral, 3 Flute\u003c\/p\u003e\u003cp\u003eMaterial: Solid Carbide\u003c\/p\u003e","brand":"Shaper","offers":[{"title":"Default Title","offer_id":54118466912603,"sku":"109289","price":159.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109289_xl.jpg?v=1789781318","url":"https:\/\/www.axminstertools.com\/products\/shaper-clearing-router-bit-16-x-16mm-8mm-shank","provider":"Axminster Tools","version":"1.0","type":"link"}
