This solid carbide engraving router bit has a 60° cutting angle for shallow V-cuts. Perfect for engraving a variety of materials including any wood type, plastic, and selected non-ferrous metals. The 8mm shank diameter is compatible with the 8mm collet supplied with the Shaper Origin CNC router. Solid carbide composition keeps your edge sharp even after hours of use. Overall Length: 54.5mm, shank: 8mm.
Shaper
Shaper Engraving Cutter 8mm Shank
| Web Attribute Set | Chamfer, Engraving & V-Groove Router Cutters |
