{"product_id":"shaper-shelf-upgrade-for-workstation","title":"Shaper Shelf Upgrade for Workstation","description":"\u003cp\u003eUpgrade your Shaper Workstation with the Shaper Shelf Upgrade Kit – a robust, precision-engineered accessory designed to dramatically expand your horizontal cutting area. Whether you're routing manually with Origin or pairing it with BenchPilot, this kit provides a stable, coplanar surface that stays flat under load, helping you achieve cleaner, more accurate results.\u003c\/p\u003e\u003cp\u003eOver three times larger than the standard shelf assembly, the Shaper Workstation Shelf Upgrade Kit is ideal for larger projects or when you simply need more support. The included adjustable support leg ensures the shelf remains level and rigid, even under demanding workloads. With both coarse and fine height adjustments, you can dial in a perfectly flat surface every time.\u003c\/p\u003e","brand":"Shaper","offers":[{"title":"Default Title","offer_id":54118778044763,"sku":"113636","price":198.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113636_xl.jpg?v=1789791599","url":"https:\/\/www.axminstertools.com\/products\/shaper-shelf-upgrade-for-workstation","provider":"Axminster Tools","version":"1.0","type":"link"}
