This scraper has just the right mix of thickness, flexibility, and strength to get under those small parts without causing damage. Fitted with a wooden handle and a stainless steel blade. Perfect if you are regularly working with double sided tape to keep your workpiece in place, you’ll find this scraper to be a must-have in your tool box to remove the workpiece.
Shaper
Shaper Stainless Steel Bladed Scraper
| Web Attribute Set | Scrapers |
